I’ve made a 24 inch diameter circle gluing 16 trapezoids together but each time I go to route the inside my piece moves! I’ve used gorilla two sided tape along with blocks screwed to butt up against the circle. Still moves!! Suggestions??
if nothing else works you could drill a few screws into the work piece and when done clue a plug or dowel in the hole and sand flush. if screws small enough use ca glue to plug themI’ve made a 24 inch diameter circle gluing 16 trapezoids together but each time I go to route the inside my piece moves! I’ve used gorilla two sided tape along with blocks screwed to butt up against the circle. Still moves!! Suggestions??
