Setting Jointer Knives
1982 Views 10 Replies 7 Participants Last post by  harrysin
Saw this, thought it might be of interest to someone looking for a(nother) way to set the knives on their jointer. I have one of the magnetic jigs, but this looked like a pretty slick way to get the job done.
https://www.woodmagazine.com/woodworking-how-to/shop-tips/the-best-current-way-to-dial-in-jointer-knife-alignment?did=254546-20180607&utm_campaign=wood_weeklyupdate_060718&utm_medium=email&utm_source=wdm-newsletter
1 - 11 of 11 Posts
That is interesting, have to remember that.
Reactions: 2
That is pretty cool, I'll have to try it out, thanks.
I just did approximately the same thing, and it really works.
A very interesting idea, but remember that only the very thin tape must be used, not the foam type.
I like this idea. I think I'd prefer to try it with Scotch Magic Tape, which is extremely thin. I'd fold over one end so I could easily peel it off.
Reactions: 2
I don't think that the article specified what type of tape to use, but I believe that I'd try electrical tape - it's thin, and an insulator, which is what you're looking for.
I’ll have to try that. My current method is to lay a hardwood block on the out feed table and adjust it until the knives just touch it enough I can feel it.
To avoid having to insulate the bar, I made mine by screwing a piece of narrow aluminum bar to the edge of a straight oak 1 x 2, with the screw nearest the blades long enough to protrude above the 1 x 2. The protrusion gives you a metal surface to connect the ohm meter, or in my case, an automotive continuity light, to the aluminum bar.
Then I sawed a through slot across the aluminum bar about an inch from that screw so it would be isolated from the part of the bar that's contacting the bed. I was able to avoid having to shim with tape to insulate the bar that way.
Electrical tape is on the thick side Charles, it will introduce a very slight error.
That's exactly the way I have done it for years tom.
1 - 11 of 11 Posts
