A common problem with table mounting the Bosch 1617EVS router is installing and removing bits from above the table. Wood River makes a 15/16″ offset collet wrench but as far as I can tell no one makes a 16mm offset wrench for the shaft. It’s a pain to have to use the 16mm Bosch wrench under the table while you use the 15/16″ wrench above the table. The solution is fairly obvious to me but in googling around I seldom see anyone take a straightforward approach to the problem. I’ve seen people talk about heating and bending the Bosch wrench or other wrenches. Quite a few people also seem baffled by the thinness of the Bosch wrench. Here's my solution.
I found this Powerbuilt crowfoot wrench set on Amazon for $14.95. Just be sure you get a set that includes a 16mm crowfoot. For some reason many sets go from 15mm to 17mm and don't include the 16mm.
Out of the package the crowfeet are a little too thick for the Bosch shaft. No problem, just thin the crowfoot down a disk or belt sander, It only took about 5 minutes to take off enough metal so that the crowfoot slips on and off the shaft easily.
I put the crowfoot on a 6-inch ratchet extension during sanding to protect my fingers from the heat and abrasives.
I didn't have to remove a lot of metal. You can still see the 16mm marking on the crowfoot.
Just use a ratchet on the extension and there's plenty of room for both wrenches and even fairly large bits from above the table.
This is an easy and inexpensive solution to the problem. Why Wood River, or Bosch for that matter don't make offset wrenches for the shaft remains a mystery. Clearly everyone who table mounts the Bosch Router runs into this problem.
