Shop heating concerns
2554 Views 12 Replies 9 Participants Last post by  CGeorge1
I have concerns for heating my small shop are in my garage. :'( With all the sawdust in the air when I'm working I am fearful of unitentional ignition and starting a fire.
I don't do much during the cold days and evenings because of lack of heat.:(
Can anyone recommend an enclosed heater I can use inside the shop that would not have exposed flame of elements yet still do the job? I cannot vent to the outside.
Thanks in advance for any council and suggestions.
1 - 13 of 13 Posts
George,
Welcome to The Router Forums.
Check out the electric oil filled radiator type heaters for your situation.
You are using your head George, smart man. Keeping your shop as clean as possible and vacuuming all the dust you can will make it safer. Use a shop vac or dust collector whenever possible and it helps to have an air cleaner to get the fine stuff. No need to go spend big money for a fancy unit, watch garage sales for one of the HEPA air cleaners like the big round one from Honeywell. You can buy these for a song most of the time. Capturing the fine dust will greatly improve your finishes too. In a clean shop you can heat with an open flame, just shut it down while you are actually making sawdust. This is what I do.
Welcome to the RouterForums.com community! :D
Hello George, welcome to the community, glad to see you decided to join.
i'm young i dont require alot of heat like adults* haha but i keep a small electric heater in the shop on cold nights for my legs mostly.
jeff
W e l c o m e . . A b o a r d !!​
I have 2 electric heaters.. One is a 1500 watt dual coil element and the other is a 1750 dual quartz.. I worry more about the quartz heater and keep it cleaned of dust..
The DC does a great job of keeping the dust down..
On the rare occasions that heating is required, I use a small blower heater, switchable 1 or 2 Kw. The airflow blows away any nearby sawdust and prevents the element from glowing. It has a temperature sensor so that it will switch off if the airflow is interrupted.
Thanks for this reply. It sinds ideal and safe!
Thanks for the reply. I have decided to use an oil filled heater because there is no exposed elements, spark, or flame. I am concerned that you are using an open element heater which may cause a fire if fine saw dust was floating in the air. Please verify it's saftey under those conditions.
Thanks for this information I will do some more research about this kind of heating possibility.
Bob N said:
George,
Bob, thanks for this reply. It is exactly what I have done.
1 - 13 of 13 Posts
