1 - 20 of 26 Posts
Adding another for the VFW fundraiser - need thoughts on which one is better, or should I make both?
This is the original design
And this is the same design - only cut out
HJ
Id have to take both..
too tuff'a call which is finer...
Reactions: honesttjohn
Nr 2 for me...both are awesome...
I like the second one the best but give them both. I mean it's for the VFW what else can you do.
Like Rick says the first one has more depth and Doug says the second one jumps out at you. Can you get both depth and cutout together, if you can then give them all 3 versions.
Discussion Starter #11
Mike,
How the heck do you do that??
HJ
Reactions: kp91
Cut the sign with the first files, then set up a vector to cutout the sign that leaves a small frame of flat material around the upper dished portion of the plaque (maybe 0.125", or what ever looks good with the proportions of the plaque). Run a toolpath using that vector to cut out the sign.
This would give you the depth and detail of the first plaque with the added cutout shape of the second plaque.
Discussion Starter #13
Mike,
So what your saying is basically to run a "border" around the top part and getting rid of the rectangle?
HJ
Theo
First one definitely does it for me, but I'd say give both. Nice job.
Mike,
HJ
Exactly!
You could just run the new vector for the cutout straight up from the upper part of the base like this.
Discussion Starter #16
Mike,
Was thinking I could make that top part (following along your vector lines) all one piece of textured granite and then cut the images in that.
HJ
Mike,
HJ
That would be even better, great idea!:wink:
Discussion Starter #20
OK -- MEBCWD tweaked the designs some for me. He's good with Aspire. Thanx Mike!!
New ones or old ones?????
HJ
1 - 20 of 26 Posts
