Let’s see what you’re doing if you’re locked down at home? This is inlay I’ve done over the past few days with the Milescraft kit and the Bosch inlay cutter kit. Using the Bosch produces a slightly different shape from that produced by the Milescraft bushings and cutter. The woods are yew and zebrano in mahogany. It’ll get a pass through a drum sander to take out the initial sanding scratches.
While I was doing this I was thinking (always a bad sign) of a way to use my Bosch inlay kit in my Makita trim router. I think it can be done, I will get a machinist to make a custom part when the lockdown is over.
JC
JC
