As a newbie (first thread!), I would like to share with you my experience with a home-made router table for my "Black and Decker" plunge router. It is 55 X 41 cm, clamped to a workmate. The top is 19 mm plywood, with 4 mm white plastic (don't know the commercial name) panel screwed to the plywood.
As you can see in the pics, the router is attached to the plastic panel using 5 more screws (replacing the ones used to attach the original thin plastic base of the router).
It is equipped with a MDF split fence, parallel rulers to determine the distance of the fence from the bit, and connected to a dust-collector.
The other pics show the very simple yet efficient riser, mounted beneath the top. It is a 3/8" threaded rod, mounted (via a threaded insert) on a base and a wooden wheel on its top. Rising or lowering the bit is as simple as rotating the wheel.
I did not take off the springs or the handles, thus when I have to use the router hand-held (which I don't like, and very rarely do) I just unscrew the 5 screws holding the router – and that's it.
I am very satisfied with the results - which does not mean I am not planning my next router table… I think it will be a cabinet-type, hopefully with a top-operated riser, and a more comfortable method for changing the bit while pushing the lock-button. I'll be happy to report.
Yair Feldmann
Raanana, ISRAEL
Yair Feldmann
Raanana, ISRAEL
