Just starting to learn routing.
Building a garden table using hardwood boards 20mm for the top. Want to join them together using T&G.
Question is - looking at T&G set (e.g. from Trend) the thickness of slotting cutter is 6.35 mm, which is a bit too thin in comparison to the thickness of the board. Would it make sense to increase the gap between cutters and use separate slotting cutter for groove (I have one ~8mm). Looking around - majority, if not all, T&G sets come with ~6mm/1/4" slot size. What's the rational here?
