hey Dog - photos of your project and issues may help with the most accurate replies.
The terminology is letter O, not number 0, flutes to describe router bits the geometry of the flutes designed for use with aluminum or plastics, and has nothing to do with the number of flutes. I suspect that if you used O flute bits you would not have the problem you described.No, not using 0 flute. Using 2 flute as I mentioned above. I have ordered a couple of 1 flute to see how that goes.
Looking at all that molten aluminum, it would seem that you are spinning too fast, or feeding too slow, or a combination of the two. As others have said, you are not using the best bit for aluminum, either.
That is way too slow a feed rate - you are overheating the bit. Not at all surprising you went through a lot of bits. If you are using 1/4" end mills, your F&S (12 IPM and 16000 RPM) yields a chip load of 0.0004", A quick survey of 2 flute amana 1/4" bits shows they recommend a chip load range of 0.004" to 0.006" for aluminum - at least 10 times larger. To get that with 16000 RPM, you would need a feed rate between 128 and 192 IPM. If you are using a 1/8" end mill, your feed rate needs to be 80 IPM.Thanks for the note. Actually, I took a deeper cut .125 with the same speed and feed and successfully made a couple of parts. The speed was 16,000 and the feed was 12ipm.
This might help you understand chip load and how it relates to F&S a little better.
