Hello,
I would like to cut some doors out of [expensive] 15mm furniture board for a camper, i figured I could knock up a template to stick to the furniture board with dbl sided carpet tape and use a router to make a clean plunge cut all the way through following the 'door shaped' template.
Looking on the Trend website there are so many to choose from, I looked at the straight bits but the smallest one that could go to a depth of 15mm was a bit with a 4mm diameter [p/n 3/07X1/4TC] - this will leave me with large gaps around the doors.
Please can anyone point me in the direction of a bit that is a smaller diameter - i don't mind drilling a pilot hole to get it started if necessary ??
thanks in advance.
thanks in advance.
