Hi there Fraternity
This is just a short one.
I’m not sure if this is borne out of necessity, or just pure boredom, but as I stood today in the workshop, I turned my mind away from actually creating something, mainly because I couldn’t think of anything to create and I thought about improvements based mainly on what annoys me when working in the shop.
To be honest the shop over time has developed and is not too bad and works fairly effectively. So I was down to nit picking and I rounded on my work bench. Earlier in the year I tore it apart and set it up more to my way of working, but the one thing that still annoys me is, not the availability of power but the access of said power. Now my 240v, 110v and air are all directly behind me when I am bench working and I am forever having to take detours around the bench to avoid snarl ups with the cables.
So what to do. Decided the 110v was staying put, due to not that much use and the air is augmented by an extending air drum to the left of my bench. So 240v it is.
I felt I didn’t want 240v drums above me, far too bulky, so decided on a drop system due to the machines I own all have a decent length of lead on them.
I started to rake about for parts and did manage to make them up but they were as you put it Eclectic, all different makes, styles and colours, and I wanted some form of unity. So, £20 for parts and away I went.
Now I had two spiral short extensions which were brilliant for the job but hung down too far and would have annoyed the life out of me, so choice was cut them in half, fit them on the other side of the bench or the one I chose, use a magnetic cupboard door closer to hitch them up out of the way, and I think it worked out quite well.
Wiring was easy enough as I had a ring main directly above.
Now at this point I had a decision to make. Either go with a couple of ceiling mounted 13amp fused spurred outlets, or 13amp plug socket outlets. I chose the latter and the reason behind this was that the trailing lead might end up directly on my head above the work piece and annoy the hell out of me, but if I use the plug-in method I could install as many ceiling sockets as I desired and move my trailing lead to which ever outlet I needed. In the end decided on 3. One on the end, one near the opposite end and one approx. centre. I have the future option of adding extra sockets.
I have also shown the wiring of a socket for the benefit of our Atlantic cousins. My son lives in Houston and when we visit I have a list of jobs to complete during my busman's holiday. One is the wiring of new socket outlets. During the time I wired my first one I headed down to Home Depot and bought the equivalent of our 2.5mm twin/earth, then proceeded to search for earth sleeve. Gave up and asked an assistant who laughed and told me he had the same problem as he was from Canada and they use the earth sleeve. In the end I bought green heat shrink. I could not bring myself the leave the bare earth in the box with the phase and neutral both having unprotected screw heads. There must be times the earth comes into contact with the live side, as you can see in the U.K. everything in the box must be totally protected including the screws. The other thing that surprised me was how loose the appliance plugs sat in the wall receptacle, unless they had an earth they wobbled about. This is not a criticism; just how different the two systems are. Well my son now has the only house in his street with all earth wires sleeved.
I’m not sure why the US is like that other than you are dealing with 110v rather than our deadly 240v. Also took a while to get used to the black being phase instead of our old neutral.
Could someone please enlighten me as to the reasons for socket wiring in the US
So that’s it lads, thought it might give some of you an idea or two if you are like retired, not allowed in the house until after dark, bored most of the time and the little things in life annoy you.
Ps. Just had a visit from the other half. Now she likes music, I like films. She also helps me clean the workshop. When it needs done I tend to dread it and I will stand in the mess looking like a lost boy not knowing where to start, while she rips through it like a whirlwind, god bless her. A lot of my comments from you in relation to my posts remark on how neat and tidy my workshop is, so now you know. Now yesterday she happened to say this would go a lot quicker if she had tunes to listen to.
So that lads, this is the next project. A stereo workshop, keep the workers happy.
Yours
Colin
Scotland
Yours
Colin
Scotland
