Your dovetail bit is set a tad too far out; adjust the depth to make a slightly shallower cut.
Raising the Bit took care of that problem as I was told.Let us know or show us how that works for you. Lyman I noticed the Leigh vacuum/router support.... love it?
Very true, not to mention cleaning up a mountain of sawdust. Not sure what's up with that left side, putting the beam on requires some effort.I haven't had that issue with mine.. the spring clips were extremely tight when I set it upbut will remember the clamp you used if needed. I love the accessory... very good dust collection. For me the support of the router from it is exactly what I needed, saves a lot of time not having to remove the router from the jig every time and saves some template nicks and gouges from being impatient.
