Hello,
New here and wasn't able to find anything related to my problem. I got a solid finger joint bit.
I run the edge starting from it's left side to it's right. Now when I assemble the workpieces one side will fit Ok but the other not so much. It's like if the bit cuts gradually bigger fingers as you move the workpieces (maybe only 1/16 inch but enough to cause problem). I assume that something must be off on the router table but can't seem to figure what or maybe i'ts the bit itself?? keep in mind that this is a 30$ bit.
Anyone had a similar problemn or could point me the problem.
(sorry for my English)
