I’ve commented in the past about how CNC cutting can be a long slow process. However, it can also sometimes produce things much faster than using conventional methods. Here’s a case in point.
I’ve been wanting to come up with a way to mount the touch-screen control panel for the Piranha FX above the table to make it easier to access and less likely to be covered with sawdust.
I came up with a simple base, arm, and bracket that could be glued up to make a little stand that holds the controller. The arm attaches to the base with two little mortise and tenons and the bracket attaches to the arm with a dado.
Normally this would require the bandsaw, drilling, and chisel work plus a few hours of shop time.
Now, the Drumroll please.
With the CNC actual production time for this project was 1:17 minutes for the base and 3:07 minutes for the arm and bracket cut. Plus, all the parts fit together perfectly the first time. Everything was glued together and ready to roll.
Fast, accurate, and easy. You gotta’ love it.
