Hi omar8
You may want to double check the model number on your router
Makita Plunge Router — 3 1/4 HP 23 000 RPM 15 Amp Model# 3612
This Makita plunge router has a powerful 15 Amp motor that delivers 9000 to 23,000 RPM for smooth, clean routing.
The soft-start feature means no more zipping across the workpiece.
You-ll get more precise routing with the variable speed selection knob.
There's also an electronic speed control for constant speed under load. U.S.A. HP: 3 1/4, Amps: 15, Speed (RPM): 9,000 - 23,000, Variable Speed: Yes, Base Type: Plunge, Collet Diameter (in.): 1/2, 1/4, Brake:
omar8 said:
Does anyone currently use an external speed controller for their Makita 3612BR? I don't know if the 3612br is considered a "soft start" router and every warning I seed advertised is the external speed controllers are not for soft start routers. The manual doesn't even mention it's a soft start and I even called Makita, no help from them. I just don't want to fry my router if I can help it. I know someone from this forum has the answer. Thanks
