Down spiral has the "edge" on the top surface (router side) coming out nicer, less splinters (think thin veneer). I've used it only as a through cutter, when hand held it makes it easier to see what is happen as the chips are taken away from the router.
They also make a compression up and down spiral bit that cuts down from router and up from the bottom side...... I don't have one of these.........
Ed
