Fibertech
Spiral SOLID CARBIDE BITS
Downcut bit is for hand held router applications. Upcut bit is for table mounted router applications.
2 flute flat bottom cutters.
Top quality micrograin solid carbide.
Will cut faster, smoother and stays sharper longer.
Produces a very clean, fast and accurate cut with minimal chatter. Upcut spiral helps remove material.
Ideal for making mortise and tenon joints.
Downcut spirals help hold the material in place while using handheld routers.
Will plunge cut and plane edges.
Eliminates chipping at the top of the cut.
Ideal for soft & hard woods, plywoods & composites,
Bj
