Hello!
Accurate work,
But what about the percent of wasted wood , making those splines ?
Regards
Gérard
Thanks, Gerard! I don't see any wasted wood. I used a 1/8" bit, spaced the splines close together, and will keep the leftover pieces for future projects - inlay, splines, banding, etc.
David those CNC machines are so neat. I may be wrong but I think you could do the same thing with a template and router with an inlay kit. For those of us who don't have a CNC machine we could act like we did. :wink:
You very definitely could do that, Don. In my case I would have to make the template so using the CNC was a natural choice.
'David, I really enjoyed watching the video, great jobs, both of making the video and doing the project. Experimenting and learning from experimenting is the best part of woodworking for me, or least it has been. I suppose that once a person becomes proficient in knowing most of the moves that the learning will not continue to be as interesting.
Would you mind telling me how you were able to post your video on the forum as you did?
I have done a lot of video production work but don't know how to do what you and others have done in regard to the forum.
Jerry
Thanks, Jerry! I agree, this wasn't anything new but represents the first time I've done anything like it so I shot the video. I'll be doing more of these but probably won't even take a photo - won't be new stuff.
As for posting video, this particular forum makes it easy if you're posting a YouTube link. All you do is paste the full URL in this window and the forum software does the rest. Some forums make it more difficult but this one is easy.
Beautiful work David, as usual. Did you consider any other shapes, such as a bow tie as often used to control splits in large slab tables, or something a little more ornamental? Based on the location of the rabbet, I am assuming you put them on the back side, and did not make a thru cut.
I am planning some furniture builds soon, and was planning on using my CNC for cutting some pockets for loose tenons (I have a fixture on one end to hold stock vertically or at angles), but I like this concept. I may adapt it, and actually feature the “tenon”, perhaps in a contrasting wood.
Thanks for sharing your idea - hope you don’t mind if I adopt it!
Richard
Thanks, Richard! I did consider other shapes but in the end decided to keep it simple. This is a display case and the door will rarely be opened. Yes, they are on the back side. Adopt away!
Looking good as always!
One thing that it took me awhile to get used to is that when using a CNC to do a job you could have done on some other tool, there is room for improvements that would have been impossible or very difficult to do on the previous tool.
I helped a student make splines for a very similar project, and just to add a little more locking strength I changed the straight spline to a dovetailed spline. You just have to make sure the shape has both inside and outside radiused corners to permit the bit you use to cut both pockets and splines for an exact fit. Once installed your miter can't pull apart even if the glue fails.
4D
Thanks, 4D! I considered butterfly splines and also .45 bullet shaped since this is a Henry .45 rifle. But simple won out in the end.
David
