Roger spray finishes are very easy to do, the normal spray lacquer would be a nitrocellulose thinners based lacquer and they can be bough in various gloss's but the more shinny you get them then the more the imperfections will show, the more matt lacquers are always more forgiving, you can also use a sanding sealer under the lacquer and that will also help to get a good finish as it will cut back smooth far more easy than the lacquer itself will cut back but you could also thin the first coat to 50/50 and spray that as a thinner first coat will sand back better, of course you can also spray turps/oil lacquers, they will take far longer to dry so if you don't have a dust free space to spray them then that can be a problem, keeping the dust motes of it until it drys, thinners based lacquers dry much quicker, it is simple to build a home spray booth to put the object in when it gets sprayed, you can make a frame and cover it with any cloth, old sheets, they wont last for a long time but they will keep the dust off it while the lacquer dries, spray lacquer is easy to do and get used to doing so you won't have any problems, just dont lay it on stupidly as more material is not better, it just will casue runs that have to be dealt with. N
