Hi
I made some panel doors, with rails and stiles, for my bathroom this past summer. Of course I allowed some space around for shrinkage/expansion and some of the panels have shrunk. The wood is pine and I used a "Minwax" one step stain and polyurethane finish. (wouldn't use again, I didn't like it) I can see a 1/16" line where the panel shrunk away from the stiles, it's a raised, darker, blobby-looking line.
The question is, do you usually stain and finish the panel before putting it in the door? If you do this, how do you then finish the small side of the stiles and rails where they meet the panel without causing stain to accumulate there? When I glue up my doors I do my finish sanding after to make sure there is a smooth transition from rail to stile, so if the panel part is already stained/finished, can it not get marred from the sanding, etc.?
Just trying to figure out the best way to do it. I'm going to tackle the kitchen next and want to improve on my work. The doors turned out great and I don't think most people would notice the shrinkage mark, but I do and it bothers me.
All ideas, discussion, thoughts, are appreciated!
~Julie~
~Julie~
