CNC machines are capable of doing many amazing things.
So I got to thinking... It is always dangerous when I get to thinking ...
WHAT IF I were to take a design for a stained glass window, and use a CNC machine to make the various puzzle pieces out of transparent or translucent acrylic rather than glass?
Normally, stained glass is held together using lead (?) or some soft material that is laid or poured between the pieces and allowed to harden in order to hold them together.
WHAT IF I were to CNC route pockets into a material like MDF, allowing for .00
" of clearance for each piece to drop partially into pockets maybe 1/2 the thickness of the acrylic pieces? Then each piece would be routed (or laser cut ... even more accurate?) to fit into those pockets with only .00
" inches of clearance around each piece, but the pockets would be spaced further apart. Once all of the pieces were laid into the tray holding the pieces in place, a liquid (soft JB WELD compound? or an Expoxy? Black Liquid Nail?) could be poured into the spaces between the pieces and allowed to harden. When fully cured, the pane would be flipped over to pour the liquid into the crevices on the other side, thus filling the gap between the pieces and creating a sturdy stained acrylic window pane.
I believe I would have to use some release agent so the "goo" would not stick to the ridges between the acrylic pieces, and the pocket tray could be reused, but in my mind at least, this SEEMS like it would be a fool proof way to create stained acrylic windows.
Do you think this would work?
Joe
Joe
