We started remodeling a long time ago. BTW, never again! Anyway, we have a stairway in our split foyer home that needs finishing. The original home had carpet and a board that was cut and routed to follow the contour of the steps from the upstairs to the foyer (foy-yay if you are formal) There is also are newell posts and spindles on that part. We are debating on some way to trim the stairs. SWMBO wants the steps to be bullnose on the front and the one end. However, my concern is getting the correct measurements for the length of the steps. I plan on buying oak lumber and routing the bullnose. These steps are oak and the finish we got didn't last. Worn down to the wood. Router is an inexpensive Skil with 1/4 bits. I would like to do some trim for the lower part of the stairs with making a template and cutting/fitting it to the contour of the bullnose and the riser.
OK, your recommendations are welcome. For some reason, the pictures are upside down. I went to the Pictures file and rotated them 180 degrees and still upside down. Help!
