Stanley Router H-260-A
1 reading
15K views 13 replies 8 participants last post by  wdelliott
I picked up a Stanley Router H-260-A. For the life of me, I cannot figure out how to lock down the router to enable me to change the router bit. If any can direct me how to do this simple task, I would be most appreciative.
W.D. Elliott
Ravenna, TX
#3 · (Edited)
Hi wdelliott
I'm not 100% sure but most of the older routers used the two wrench way,,
Look for two flat spots on the arbor right under the collet nut, if you find them pull out a wrench from the tool box that just fits it, just right..if you don't have one that thin you may need to make one out of some flat stock...most call them service tool...very thin and short the norm..
Another question on the Stanley router
Bob,
Thanks again.
I have a1/4 collett on the Stanley 360, but want to move to a 1/2 inch. Is this possible on this router and if so, would you ahve a source of supply to suggest to obtain the 1/2 inch collett?
HI wdelliott
Nope sorry, back when the Stanley was one of the king of power tools they didn't have 1/2" shank bits...but I will suggest you pickup one of the NEW Craftsman router combo kits for 100.oo dollars, it comes with many new items plus the 1/2" collet, it will blow you away,,they are that great, I have been a big PorterCable fan for a long time and they have switched me over to the NEW Craftsman routers..
But keep your Stanley for hand jobs they are great little routers. :)
Bob,
Thanks again.
Greetings W.D. and welcome to the forum, great place to make friends and further your router abilities.
Does the on/off switch have a notation "lock" If so put the switch on off and pull the switch lever out and up till it clicks... this locks some of the older Stanleys ...ahhh yes besure to unlock it before trying to start it --want to see the broken pieces...
Stanley 260: Lock bit
Everyone,
Thanks for the solution. The on-off switch pulls out to lock the router to enable the bit to be changed. You can't believe how long I stared at this router trying to figure this out and the solution was simple and right in front of me.
I'm not feeling especially adroit with machinery at this precise moment.
W.D. Elliott
Ravenna, TX
#13 ·
This is a rather late reply but the on/off switch lever locks the motor. In the off position, the lever can be shifted to a cutout on the side of the slot that the lever rides in. Doing this shifts an internal lock into place. To see how it works just take the router's top cover off - the mechanism is right there on top.
