Hi Slojim
You may want to take a look at the web page below,many great books by Oak-Park (RWS) with many,many great ways to use your new router and have some fun also.
see linnk below ▼
http://us.oak-park.com/catalogue.html?list=RW-Book-&ref=usa12.html
I should note***It's hard to make any thing with out a router table, you can make one quick and easy till you get then hang of the router and then make a nice router table.
Take some 3/4" Plywood (16" x 18" )set your router on it ,draw around the base and mark the screw holes that holds the plastic face plate to the router base,(on the out side of the line) then pop in a bit and plunge down a 1/2" deep and remove the stock inside of line (start with the center and move out to the line,leave a small nub in the center this will help hold the router true for the plunge cut) then center the router in the hole and plunge all the way into the plywood so it comes out the other side.( you want to end up with a 1 1/2" hole in the center) a Hole saw will work great for this job.
Now take the plastic face plate off the router and mark and dill the holes into plywood to hold the router to the plywood.(you will need to couter sink the holes on the top of the plywood) but I'm sure you know this.
You can clamp the plywood to the work bench or screw it down or pop it in your WorkMake bench or what every.
Now find a true 2 x 4 stock for a fence,clamp it to the plywood, you just made a quick and easy router table that will work for many projects for 2.oo bucks or less.
Bj
