If I was going to start a dado for a cabinet door frame and start it 2 "from the end of the stile is there a way to set a start block like a stop block??I would use a 1/4 " straight bit for the dado. My stiles are 23 and 28 inches long and routertable is only 24 inches over al lenght so it is only 12 inches from cutter to end of table. I was thinking of drilling pilot holes on either end and drop the bit in the hole and the mark on the fence where the end of the cut will end up so I dont run it to the end of the work.
