well I recently had my house covered in Acrylic rubberized stucco, there was some left over so I attempted to make a stucco planter.
Is that the product that you install styrofoam sheets and then trowel on a layer some kind of material,then spray on the thick rubbized top coat?well I recently had my house covered in Acrylic rubberized stucco, there was some left over so I attempted to make a stucco planter.
it can be, when they did my house they put a skim coat on of a concrete base because I had already had a concrete base but I had changed all the windows and of course none were original size. then they applied the stucco entirely by trowel. here are some before and after.Is that the product that you install styrofoam sheets and then trowel on a layer some kind of material,then spray on the thick rubbized top coat?
That is the regular old cement stucco. The new "Stucco" on commercial building they put 3 1/2" styrofoam on and the trowel on a subbase then spray on a finish coat.it can be, when they did my house they put a skim coat on of a concrete base because I had already had a concrete base but I had changed all the windows and of course none were original size. then they applied the stucco entirely by trowel. here are some before and after.
this is premixed colour based fine float acrylic stucco and not cementitious stucco which is the old style. it can be applied both ways either spray or by float.That is the regular old cement stucco. The new "Stucco" on commercial building they put 3 1/2" styrofoam on and the trowel on a subbase then spray on a finish coat.
HErb
Can it go directly onto wood Brian? I built part of my house on top of a PWF foundation. I've been trying to think of what I can use to finish the small section between the ground and the bottom of the siding. I was thinking regular stucco but I think the elastomeric would be better.Chuck it is just acrylic stucco or EIFS. It was invented in Germany after the war as a quick alternative to regular stucco. Dryvit was the first iteration of it I think. It was first used in Canada around 1956. I worked on the first building to use it in Victoria in 1974 an 18 story hi-rise in James Bay. It has certain elastomeric properties and usually goes over a styro-foam sub strata but can go over a well floated cement coat.
Yes it can Chuck in a sort of round about way. It is really made for the foam board base which is not like regular styrofoam. It is cooked somehow so that it does not expand and contract with temperature changes. The foam is stuck on with acrylic base coat using a largely notched trowel and reinforced with heavy fiberglass mesh over which the acrylic base coat is spread (sand and acrylic liquid to which you add portland cement). Spreading it takes practice. It is put on tight and as flat as possible as the finish coat goes on very thin and doesn't hide blemishes.Can it go directly onto wood Brian? I built part of my house on top of a PWF foundation. I've been trying to think of what I can use to finish the small section between the ground and the bottom of the siding. I was thinking regular stucco but I think the elastomeric would be better.
Not necessarily, Herb. I think you're referring to EIFs... https://www.homeadvisor.com/r/synthetic-versus-traditional-stucco-siding/That is the regular old cement stucco. The new "Stucco" on commercial building they put 3 1/2" styrofoam on and the trowel on a subbase then spray on a finish coat.
HErb
Not a good idea, Charles. it traps moisture and contributes to wood rot. Put a waterproof membrane on first. You could use something like Hardiboard over the membrane as a base if you don't want to go the whole scratch coat route.Can it go directly onto wood Brian? I built part of my house on top of a PWF foundation. I've been trying to think of what I can use to finish the small section between the ground and the bottom of the siding. I was thinking regular stucco but I think the elastomeric would be better.
You are right about EIF, but it is applied to sheets of foam.Not necessarily, Herb. I think you're referring to EIFs... https://www.homeadvisor.com/r/synthetic-versus-traditional-stucco-siding/
They trowel or spray on Vinyl or Acrylic stucco topcoat over cement scratchcoat here, on residential construction. I've never seen them use styrofoam.
The norm here is to do the Tyvek and rainscreen consruction, then stucco wire and two coats of cement based stucco with coloured Acrylic coating as a finish.
http://pacwestsystems.com/wp-content/uploads/2015/02/Sanded-E-2014.pdf
