I believe that before achieving success in woodworking one must also experience failure of some kind as well. Additionally, like I use to tell my students and staff, ask questions before you make the wrong decision.
After putting the splines in (end grain facing out this time) I cut the lid off (success) without a hitch, well sort of. I must have watched dozens of videos on how to do it and went with the way Marc Spagnuolo (Wood Whisperer) does it. https://diysynthcases.com/how-to-cut-off-a-box-lid/
The failure was that the lid did not matched the case. When I looked at it there was a saw cut on the vertical portion of the lid. Not only was I cutting along the horizontal as I pushed the box through the blade, but the vertical part (leading edge and trailing edge) was also getting cut.
Where did I go wrong? Was the blade set too high. How do I determine at what height to set blade?
Luckily, I can use the remaining portion to try again as a test. My other options are to cut just short of the all the way through and saw it off or build the lid separately.
Thanks for the help.
