Donny...I would stick with the Dremel and their accessories. For example, you could freehand with the wand or use the Dremel like a router with its plunge router attachment (335). They also have a base attachment which is fixed and smaller. It is height/depth adjustable. These attachments will make freehand much easier as they steady the Dremel tool.
As for the template you could do something as simple as using your computer fonts, print something (name, message, image, etc) then use carbon paper to transfer it to the workpiece (box, sign, etc). Then use one of Dremel's router base attachments to steady for freehand.
Dremel's bits will make it easy also...v-bits, ball bits, straight bits, etc... depending on the effect you might want.
Then just stay within the lines...:grin:
