Hi gang,
I'd like to create some circle one piece frames, for my partners cross stitching.
I was wondering what you experiences were in doing this task?
I have a few ideas/possibilities in my head. Basically, I created a 3cm wide frame, with a full diameter of around 20 cm (to outer circle). I want to put a simple round edge and rabbet in the inner circle and a nice ogee on the outer rim.
To start, there's cutting the circle. I've already whipped up an MDF template (flush, no bushing space) for the circle, just in case I need it for table top work (I guess that's for you guys to say!!).
I've got a circle cutting jig for my Triton plunge, so should I cut the circle(s) with that? In shallow passes? Or should I jigsaw it out and flush it up on the router table?
Then, what's the best (or probably most stable/safe) way of using the edge bits? Should I hand route it, with or without template, with bearing? Or should I attach the template and use the table top with a starting pin? I'm especially concerned about the inner circle rabbet cut, and how to get a nice smooth feed while keeping my fleshy bits safe
Looking forward to your feedback! Any many thanks in advance
Jimbo
Jimbo
