1 - 9 of 9 Posts
Oliver (Prof. Henry)
Discussion Starter #1
In a recent post about making pulleys I mentioned that I was going to make a drive belt for them and said I would show you how I do that. This technique could also be used to make an emergency O-ring of any size.
For my drive belt I used 2mm O-ring cord that I stretched between my pulleys and marked the spot to cut. Cutting was done with an exacto knife but a razor blade or utility knife would work as well.
Now, here’s the easy but surprising part: a tiny drop of superglue is applied to one end of the cord and then the other end is pressed against it for about a minute. When the glue has set you have a drive belt and/or O-ring.
I made a small test ring first and when it worked I moved on to my longer belt. The small belt is about 1 3/4” when measured between the two legs of a caliper. I was able to stretch it to over 2 3/8” without the join giving way.
[Sorry the close-up photo is the join is so blurry, I couldn’t get my phone to focus on it.]
There is enough stretch in the belt to give me the tension I need to drive the pulleys and it’s easy to make another if needed. Maybe you’ll find this technique helpful someday. The O-ring cord came from … (where else?) … Amazon.
I've used that method for making 'static' O-Rings, but never trusted them in moving applications. It's good to know that they're tougher than they look!
Can't wait to see the final project
Thanks for that Oliver. I always thought it had to a solvent based glue. Good to know.
Paul
Very interesting but I wonder how that would withstand weather and UV from the sun???
Thanks for this info. I may be able to use in on some of my wife's sewing machines.
Allen
Great trick! Thanks. It's worth knowing just the simple fact that O-rings and drive belts of the same size can be interchangeable.
1 - 9 of 9 Posts
