Supermax 1938
2.2K views 3 replies 4 participants last post by  xxaquadogxx
Love this to date. however anyone else hear or see of this problem before?
If so how did you rectify?
If I am seeing correctly, it looks like the wheel housing is bad, I would replace the wheels. If one has bent, I wouldn't just replace one as they are all probably overweighted. Do you need to use whatever tool it is as a stationary tool and just move it at times? If this is your situation I would recommend these
They are rated for 600 lbs, mount with the supplied plate or directly with a bolt. They allow you to level your tool or bench through the wheel that lowers the stationary feet, seen in picture 2. They cost me 54.00 from a company out of Kansas City, purchased through eBay. These casters are awesome and work amazingly well for any application I have thought of, unless larger wheels are needed. They also have them for heavier applications. I hope this helps.
Sent from my iPhone using Tapatalk
