I am making a jig which uses UJK Technology Universal T-Track, it is 19mm wide 9.5mm deep and the length after trimming will be about 700mm channel.
I propose to cut the channel using my Festool router with 1/2 collet and the Festool track which will be clamped to the workpiece.
The board I will use for the jig is a laminated plywood which I think is 18mm deep.
I expect I will need at least two passes to get to 9.5mm depth
I have two questions
1, What type of router bit should I use?
2, In which direction do I move? normally I would move the router away from me
Regards
John
Regards
John
