Welcome to the forum.
I was planning on using live edge, so that would be difficult, but it’s definitely something to keep in mind if I have to go in another direction. Thanks!The wider the single piece of wood the more likely it will warp, especially if used outside. Why not glue two boards together with a good exterior glue.
Hi Newbie! I believe tamarack to be hard/dense. Probably tend to dull your bits. Should be fine results as far as I know. Eastern Hemlock is very rot resistent, not all that pretty and tends to be splintery and rather inexpensive. 6/4 Hemlock should be good but probably too thick for a sign blank unless it's a bigger sign... Probably quite local to you, as wellHi all! I’m planning on making my first router-based cottage sign. Everything I’ve read says cedar is a great wood to use, as it’s soft but very durable and rot resistant for outdoor use. I live in Ontario, Canada, so we get extreme temperatures here: from very hot to very cold. I’m having an extremely difficult time procuring a cedar slab though. I’ve tried many different wood mills and most is only 8” wide and I’m looking for something wider for a sign. One guy suggested using Tamarack wood instead. I looked it up in the wood database and it seems to be a softwood with decent rot-resistant properties, but I’m not sure how comparable it is to cedar for routing letters. Has anyone ever used Tamarack wood for this purpose? How was it?
Thanks in advance!
