1 - 2 of 2 Posts
I've been working on a table game board.Started with a veneered piece of plywood and
applied four coats of amber shellac,sanding between coats for a fairly smooth finish.
So far so good,then applied"Scotch brand Painters Tape" to outline the areas of play.
Then used acrylic craft paint for the various play areas,all went well till I removed the tape. The paint edges were crisp as advertised but the tape appears to have lifted the
finish of the shellac(no longer shiny). I coated a sample piece with shellac and painted stripes of the various colors of acrylic craft paint,after allowing it to dry gently wiped the entire surface with a cloth lightly coated with alcohol thinking a light french polish technique might restore the shellac's finish.Sadly the alcohol removes the acrylic paint as well ! I'm stuck for a solution and would appreciate any and all help....
Thanks in advance,
Don
Thanks in advance,
Don
Don
You can spray clear shellac over the board after your acrylic paint has dried.
Al
1 - 2 of 2 Posts
