I don't see why not Duane but it will only be effectual on the outfeed side unless you are feeding both directions which is always something to remember when cutting grooves on a table. If you are using a bit that requires two passes and moving the fence in between you have to be careful to do it in the right order or the second pass will need to be reversed, i.e. left to right instead of right to left.
If you make the first pass and then move the fence back you stay with right to left but if you move the fence ahead then feed direction and bit rotation are in the same direction so that pass should be reversed feed direction instead.
