I will still use the guide bushes even if I invest in a pattern bit set.Yes I understood that but am wondering when you would have a use for guide bushes if you invest in a flush trim pattern bit. Wouldn't it make the guide bushings unnecessary?
Sent from my GM1917 using Tapatalk
Here's why
As you plunge, the bearing of the pattern bit may still high up and so the cutting edge could destroy your template.
So you need a pattern bit set. Use the short pattern bit first then change to a longer bit for more depth.
The guide bushing on the other hand will always protect the template from being accidentally cut and damaged.
