1 - 2 of 2 Posts
Discussion Starter #1
(INCA I-BOX JIG) I posted earlier asking about this jig. It was quite new then. I am now asking, has any one tested and used this JiG? The research is favorable for the jig. I am not a real pro by any means at woodworking, but enjoy working with wood. So I am very interested in the the I-BOX JIG. I know it is a bit expensive, but for what I am trying to do, I think it may be the way for me to go.
If you use it on a table saw, then the calibration is once off but you are limited to the widths your dado blade can be configured for.
If you use it on a router table, then you will need to calibrate every time you change the bit diameter. Upside is that it will work with every conceivable straight/spiral bit, be it metric or imperial.
If you have a router that is attached to a table saw extension wing then the miter slot may be too far away.
Otherwise, just go for it.
1 - 2 of 2 Posts
