I started this in response to an old string started in 2012 by Harry which was recently reactivated but I decided to just start a new string. Opinions are still coming in so I'll throw my 2 cents worth in. Isn't it interesting that people throw their 2 cents worth in but others are only willing to give a penny for your thoughts? But I digress. I won't touch on the metric topic but will say that an inch is an inch no matter what you call it. I have three routers, two are plunge 3 1/2 hp which are way to heavy to use by hand, and one smaller fixed base one that I haven't used in about 3 years. The plunge routers are mounted on plates to use in a table and the springs are removed. So I guess that tells the world that I don't have much use for the plunge feature. As for guide bushings, the ones that I got with the router have never been used. If I need to make something like a curved edge I make a template and use a pattern bit which by the way doesn't require accounting for an offset calculation which can easily cause a mistake. The bigger question that I raise all the time is why does one use a router not mounted in a table? A handheld router certainly isn't as safe, accurate, or easy as a table-mounted when doing edges or doing grooves which is what a router is made for. I know the argument that you can't do mortises with a table-mounted router. Okay, how many mortises does the average person make? More than one a day? a week? A month? If your work requires mortises then buy a mortising machine. Do you make hinge cutouts? If so the buy a small 1/4" router and the correct setup. Do you make carved-out things like bowls? Then buy a lathe. I'll give you this you can't make signs with a table-mounted router. How many out there have ever used a wrench to drive a nail? It sounds crazy because a wrench is not the best tool to use although it does work. How about a screwdriver as a chisel? You see the questions on the form all the time. Can I use a router to cut a board. ( yes but use a table saw) How do I make a dado for a shelf (use a table saw) how do I make a series of holes 2" in diameter (use a hole saw) How do I make dowels (buy them) the list goes on. I have zero use for a handheld router and I use the router almost once a week. I can't imagine that the type of work I do is much different than the average person does yet I get by without ever having to take the router off the table.
