No Tom.
I only have those 3 bushes.
There are times when different size bushes might be useful but the ones I have suit me.
Jig following is the only reason I use bushes for and the jigs I have made are for the 30mm bush.
As all accessories in Europe are metric and many of my cutters are in inches, it can take some time calculating the difference between cutter and bush.
I therefore make a jig for a particular cut using a known cutter size.
Anything bigger than my normal use and I would use a straight edge guide offset from the router base.
I'd never use large diameter cutters hand held.
I'd use the router in a table.
I am waiting to get a 1/2" router before using any large bits.
At present I raise door panels on the table saw but would prefer the finish of a panel raising bit.
It's not safe running a panel against a fence set at 45° to the blade and raising the blade a little for each pass and the finish needs a lot of sanding with my ROS.
As soon as I am able I will be rebuilding the workshop to take account of the tools I have and new ones I intend getting.
I cant do this until I build a shed to take all the garden tools, mowers, shredder etc as they take up too much space in the workshop (garage)
