I use the Triton and my table is made up of two thicknesses of 18mm MDF.k.birrell said:
The table shows no sign of sagging so far.
beejay
http://community.webshots.com/user/eunos9
I use the Triton and my table is made up of two thicknesses of 18mm MDF.k.birrell said:how thick should a table top be when using a triton router (13lbs). i plan on using mdf material.
Hey beejay, nice shop. just from looking at your shop I would guess that your are from somewhere in europe. Am I correct? and that you golf too.beejay said:I use the Triton and my table is made up of two thicknesses of 18mm MDF.
beejay
hi Mike,golfmike304 said:Hey beejay, nice shop. just from looking at your shop I would guess that your are from somewhere in europe. Am I correct? and that you golf too.
Beejay, I was looking at your pictures of your shop.I could see the golf balls in one of your cabinets, and also seen the plugs for your compressor and router that led me to think you were from across the pond. I don't play as much golf as I would like but I hit the ball pretty long and straight. I like how orderly your shop is. I work in an instrument shop at a chemical plant in West Virginia, and there are a coulple of guys that we work with that are that neet also.beejay said:hi Mike,
Yes, Im from the UK ( we still see ourselves as separate from EuropeI live very near a small City called Chester which is about 40miles from Manchester.
And yes, I play golf when I can find the time, dont know how you figured that out mind you ?
I see that you also play, and with a name like that, probably a whole lot better than I do![]()
Thanks for your post and nice talking.
beejay
http;//community.webshots.com/user/eunos9
