thin wall pvc pipe problem
6.1K views 6 replies 5 participants last post by  Mike
Hello
Need some help. I have many lenghts of 3/4" thin wall pvc that I need to slice a 1/2" slot down the middle of so that I can snap them over a 1/2" steel pipe. I have made a jig to hold the pvc and tried to use a router but all it did was chip and crack the pipe. Was it the speed of the router? Type of material, or perhaps the bit? Please help if you can. Thanks in advance!
Hi, you may wish to hold the router still, (clamp in a vise of some sort), move the pipe over the bit. What type of bit are you using... straight, spiral? I prefer spirals.
#3 · (Edited)
Hi Tim
Sounds like it needs a bit of inside support ,,,(so it can't flex) I would try some dowel rod down the PVC pipe then tape the ends up so the dowel can move out of the pipe..until you have the pass done also just a small cut say about 1/8" deep..
You can also use a pair of 3/32" slot cutters on the same shaft to get the 1/2" wide slot...( on the router table) but again only 1/8" deep...
Don't know if you have a bandsaw, but I cut a slot down the length of PVC pipe on mine. Just put a fence 1/2" (or whatever you need) from blade and then run the pipe through the blade. Worked fine, zero tearout.
I tried that but there was to much movement in the pipe I could not get a clean cut.
Timothy
Timothy, to make this work you must consider the forces exerted on the tubing. You need to get a small section of 4" x 4" perhaps 6" long. Drill a hole through it sideways that the PVC will just fit through. Clamp it to your fence and raise your bit up through it for the desired cut. Next you will need a dowel to fill the PVC from end to end. As you pass the PVC through the hole your cut will remove the material and the dowel and hole will keep it from shifting. Once finished remove the dowel and insert it in the next pipe. This method will guarantee uniform cuts.
