Hello and welcome to Router Forums, n/a (I'd put a name in there, but you didn't fill it in)
I'm sure that other members here will chip in with helpful suggestions about your little article. Might I ask if it is a high school project or something similar?
I'll add a few remarks of my own for you to consider.....
You seem to think that shaping can be done with smaller routers. Well, that isn't always the case, either. If you want to do large size panel raising, shape stair handrails or cornice (crown) mouldings that can be done by a router, but for the bigger router cutters you need as much power as you can get. Really. On the other hand a 1/4in roundover cutter can be chucked in a 600 watt (7/8HP) trim router and work well, proviiding you aren't routing a hard plastic like Corian. Power required equates to the cross sectional area of the material you are cutting as well as to the material itself - MDF is easier to work than cocobolo or Corian.
As regards safety you've missed several key points. Routers are extremely noisy and hearing defenders are a must because prolonged use over time will induce hearing impairment. Routers can also generate a large amount of fine dust which is going to cause respiratory problems (some species are natural irritants - and very fine wood dust can be carcenogenic according to the OHSA), so respiratory protection, a mask and preferably some form of dust extraction, are a must. You've also missed the need to protect the eyes. Some tasks, such as laminate trimming, generate small sharp particles which can give router users problems if the eyes are not protected by some form of safety spectacles or visor. Obviously the need for respiratoty and eye protection is reduced if the router can be kooked-up to a vacuum cleaner, but it doesn't go away
Regards
Phil
Routers don't often perform the same tasks as chisels and hammers IMHO. Sure, they can make it easier to hang a door, but for a one-off it's still a lot faster to use hammers and chisels, and auger bits, cordless drills, etc, rather than break out a router. Other than that routers really replace a whole slew of planes
I reckon you'll find a few folk on here who will disagree with that statement. There are some tasks where the lower centre of gravity and lower weight of the fixed base router is a boon, e.g. freehand sign work. They are probably more suitable for use in router tables, too. Whilst I mainly use plungers I can't say the fixed base routers I've used were particularly uncomfortable evem over extended periods of use (but some of the plungers I've used had dire ergonomics)
Regards
Phil
