I need some help for a project for my wife, the project is a quilt hanger for her prize wining quilt that is 84"+/- wide. The hanger will be about 3" wide and out of 4/4 hard maple with one or two 1/4" through inlays running the full length of hanger much like the cutting boards featured in Fine Woodworking a year or so ago, only on a massive scale.
I'm thinking the safest and most efficient way to make the curved cut for the inlay is to make multiple passes with a spiral bit in a template bushing with a temple taped to the work piece.
I have seen several videos and articles that suggest routing a grove in the curve shape you want then band sawing down the middle of the grove and finishing the cut with a flush trim router bit. Tried that and split out several chucks as I got to different locations in curve ruining a nice piece of wood.
So here are my questions:
1) Can I reasonable make through cut in 4/4 hard maple in several passes using a spiral bit?
2) Which spiral bit should be used up, down, compression?
3) Any one tried doing curved inlay any other way?
I would greatly appreciate any help or ideas you provide.
Thanks guys
Thanks guys
