Toastmaster router
1337 Views 7 Replies 7 Participants Last post by  TenGees
I got a router on Ebay for 10 bucks with free shipping. When it arrived, I found out it is made by Toastmaster( it has the name on it), model 5545. It works, and quite nicely at that.
However, I seem to have a problem. How do you adjust the depth?
1 - 8 of 8 Posts
It looks like the style that uses the black twist ring to raise or lower the motor into the base
G'day and welcome to the forum.
As Doug said, It looks like the style that uses the black twist ring to raise or lower the motor into the base.
Based on an older model fixed base router....
How does the twist ring change the height? It's loose enough to spin well enough, but nothing else moves. I don't have a manual, either, so I'm groping in the dark
Welcome to the forum.
Liquid Fluid Drink Gas Cylinder
Welcome to the forum. I found this picture online of a Toastmaster Router is this like what you have ? There should be some kind of lock mechanism that you would release to move the router in its base when you turn the ring. It may be the black hand knob on the left side of the image try loosening it and see if the router will move when you turn the ring. Hope that helps if you could post some pictures that may help also.
I think if you twist the ring far to the right, your toast will be darker. If you overheat the thing it'll be toast itself.
Turning the ring should raise or lower the motor compared to the base. That changes how much the bit protrudes below the baseplate (depth of cut). Some fixed-base routers also have a lock but I'm not sure that kind does. There should be threads and that ring should move on the threads like a nut does on a bolt. Perhaps it's thread are stripped? There's a manual here for a Craftsman router that adjusts height in a similar way. Maybe that will be of help.
1 - 8 of 8 Posts
