Hi Tommy:I saw that bit, and didn't understand why there were two bearings. The video shows it quite clearly. Maybe that's the one I should go for. My body blanks are usually 46mm thick, so a 2" cutting height will be enough..
Tommy
I'd second the double bearing bit suggestion.What do you prefer? Flush trim bits with top-bearing or bottom-bearing? Are there any pros or cons that I should know about?
God I love this forum. You don't get stuff like this anywhere else. Bang on! My solution was always to leave 1/32" to be finished by hand. Now, I know better.I'd second the double bearing bit suggestion.
Some solid lumber consistently breaks when routed in the wrong direction with respect to the grain (I learned that the hard way).
This is good:
wood grain
O bit (rotates clockwise)
hand-held router moves ->
the wood fibers move out of the way like on a feather board
This is bad:
wood grain
the fibers catch like on a feather board
Where curves cross the piece going from good to bad you want to flip the work over so that you can keep moving in the right direction to avoid breakage without making a climb cut.
Solutions are to flip the work in the pattern (which only works for symmetric pieces and is easiest if they're held together with toggle clamps) or flip the work and pattern over.
In the later case you need both flavors of bits (in which case you need to change them) or one bit with both bearings so you can just change the height.
An overarm pin router is a lot like a drill press or vertical mill with a plunging spindle on top. Pattern work is done with a table mounted pin that engages a pattern beneath the workBy definition, a flush trim bit has a bearing on the bottom and a pattern bit a bearing on top (of the bit), no matter whether used in a handheld, table, or pin router.
I don't understand why a pattern must be on the bottom for a pin router. Wouldn't this be the same as using a handheld router?
Hi Tommy,"Are there any pros or cons that I should know about?"
For stock as thick as yours I'd use neither.
A plunger, collar and stout (>3/4"CD) straight cutter would allow safer stage cutting.
Hi Tommy:I will be using a bandsaw to rough cut the body, leaving maybe 1/8 or less wood to be routed away. For the different cavities on the body, I'll be using a plunge router with templates...
Tommy
All router bits are dangerous and the same precautions should be taken anytime there is a bit in a router. A bit is dangerous even when the machine is unplugged. Anytime you use a router bit follow all of the manufacturer's warnings and instructions. Especially, watch the RouterWorkshop videos and familiarize yourself with the operation you want to perform before trying it yourself.A couple of long-term considerations re: top (shaft end) versus bottom (cutter end) -affixed bearings:
1) Top-affixed can be extremely dangerous, hazardous to you, workpiece, etc., since you are committed to exposing 100% of the cutter length, whether hand-held or table-mounted. With bottom-affixed, you only expose as much of the cutter length as you need. Bottom-affixed flush cutters are safer and more versatile in my book; if I had to choose just one, I would always go with the bearing on the cutter end.
I'm not in favour of putting tape on a template. It usually takes me a lot more time to make the pattern and then the template than it takes the make the final product. When I make the template, I want it to have the exact dimensions that I need in the final product. I don't want to have to reconsider my dimensions. Also a tape will introduce errors itself. Especially where the tape may be applied less than perfectly.3) Good discussion about dual-bearings, climb-cutting, thanks all. Just a thought: if you get some 3M metallic tape, you can line your pattern with one or more layers of tape and do all your brutal cutting against the tape, carefully observing the aforementioned grain issues. I too prefer climb cutting, as tear-out on contrary grain can run deep, and flipping is not always feasible. Practice! Slip off the tape, wipe with solvent to remove adhesive residue, then make a light final pass, by now knowing all the nasty places on the workpiece very well.
I second your concerns for safety but rather than condemn working with an open bit, which I do routinely, I have to refer to the Router Workshop and their use of a safety pin. Plus, never start the router without three points of contact.4) Take you time, brace yourself for "grabbing," and most importantly, mind those fingers, **ESPECIALLY** with a top-affixed, 2" long, and table-mounted bit sticking 100% out of the bench.
