3D laser scanner???
When you use a touch probe, you get back a “point cloud”, a bunch of X,Y,Z coordinate sets. Fusion 360 will not handle this directly. You will need other software to transform the point cloud into a format that fusion will accept. I think MeshLab will handle the conversion, then you can use Meshmixer to edit and finally import into fusion as an STL. Not trivial, but not impossible, and luckily these are free software programs.Is there a way or supplier of a touch probe to expedite the programming of shapes in CAM. Example: If I wanted to copy the interior dimension of a bowl, can I do this will a probe and send data back to Fusion?
Thank you
In Mach3 there is a Wizard utility called COPYCAT using a webcam to do that.Is there a way or supplier of a touch probe to expedite the programming of shapes in CAM. Example: If I wanted to copy the interior dimension of a bowl, can I do this will a probe and send data back to Fusion?
Thank you
