I am using the tongue and groove router bit set from Sommerfeld to make some cabinets. They advertise that each bit is made to match perfectly so you do not have to adjust bit height between set-ups, just bottom out the bits on the rubber grommet they provide and you get perfectly matched joints every time. The problem is my shaft is about 2 in. deep and the shaft on the router bits are much less so they don't bottom out in the router. What this means is that I have to manually change my router height/set-up between bits.
I have a Porter Cable 7518 mounted in my router table. I am not aware of any adjustment I can make on the router shaft depth. If there is no way to adjust the shaft depth in the router, then is there something I can insert into the shaft that would raise the bits so this joinery system works as advertised? Sommerfeld has a great video but it fails to address this problem.
Any ideas/suggestions are appreciated. Thanks
