this will show that placing a projected light 90 degrees to the drawing table
casts a shadow that can be traced and a dxf file created to allow a fitted foam
insert for that object using the CO2 laser to cut it
stankern.vids.io
tracing an object using the shadow effect
this will show that placing a projected light 90 degrees to the drawing table casts a shadow that can be traced and a dxf file created to allow a fitted foam insert for that object using the CO2 laser to cut it
