It's the age old art called decopage. Print out the picture, glue it on with a product called modge-podge available at craft stores.
Hi,aniceone2hold said:The pantograph I mentioned would be used only for doing a layout. Ed might be able to answer about the duplicator with a router attached. Seems like he mentioned one in a post.
Cubbie I do this all the time. I am also a pyrographer(woodburner). When I want to transfer images or patterns to wood, I go to OfficeMax and copy the image I want on a copier that uses toner. It will not transfer with inkjet ink. I have a small heat transfer tool with a round disk on the end and turn the image with the printing facing the wood and pressing tool on the paper in circles making sure I have transfered the whole design. For real large images you can use an iron. The tool is available at Woodcraft or any craft store that sells woodburning supplies.Cubbie said:I had a question that hopefully someone will have an answer to. I have a high resolution picture on my computer that I want to duplicate on a piece of plywood. Now short of hand painting it on to wood, does anyone know any better method?
I was wondering if there was something like heat transfer paper or something similar to which I could print on, then align it up and iron it on and seal it with a lacquer.
Has anyone tried anything like this before?
