Trash to treasure (sort of)
3427 Views 13 Replies 9 Participants Last post by  beserkleyboy
6
I came upon an old storage cabinet when looking for something to repurpose into storage in my youngest's room. She eventually found a old desk with about 7 coats of paint on it, but that is a story for another time.
We pulled into the owner's driveway and the nice old lady who was selling it told me it was something her husband had built a long time ago. It wasn't in as good of a shape as the pictures made me believe, but the drawers were rock solid. I gave here the few bucks she wanted for it, and we threw it in the truck.
When I got it home, I couldn't decide what to do with it, whether just reinforce the original carcass, or rebuild everything around the drawers. the 1/2 inch ply sides and bottom were delaminating, so I decided to take them off and replace them with 3/4. The solid wood drawer frames and the drawers were in very good shape.
I stapled some fence pickets to the drawer frames to keep the spacing as I pulled the sides off. There were only about 7000 small nails holding this thing together. The drawers were not quite interchangeable, and I was hoping to get off easy and not have to do too much measuring.
I didn't change too much in his measurements, except to shorten the original overhang he had on the sides and front, which I thought looked kind of cool, and gave it a more stable base. I also turned the casters 90 degrees so they were in line with the long axis instead of the short axis.
The edge glued pine top is the remains from someone's discarded Ikea desk, and I think it will go well on this piece. For less than a sheet of plywood it turned into a very solid shop cart, or maybe a pen turning workstation. I may edge band the ply, but for now it's fine the way it is. I have one vote in the house to keep the colors as is, and another to paint the plywood in an earth tone chalk paint finish.
1 - 14 of 14 Posts
Not thrilled with that primer white; needs something either really close to the wood colour or an analogous solid colour (semi gloss?)
Color Harmonies: complementary, analogous, triadic color schemes
Maybe something like a Burgundy?
Now that there appears to be a white primer, stains are sort of out of the running.
What a difference.Something old is new again.Great job Doug. James.jj777746.
that is unfinished pine ply. Some of the most boring grain on it. I think it will be a Matte Brown or Matte Green.
Reactions: 2
I think that turned out great . What a transformation :)
Great rebirth Doug.
Not really relevant, but whilst searching for painted furniture pics I came across this silver painted piece; Holeeee Hanna...
https://proxy.duckduckgo.com/iu/?u=...1981590421--silver-paint-silver-spray.jpg&f=1
I've used the sample size paint @ Lowes, mixed to the color I want. It would be about the right amount for two coat on your project for about $3.00. Mixed to the color of your choice. Just a suggestion. It's no longer an ugly duckling! It looks like you will get good use of those drawers.
A man after my own heart! I live of paint samples and the OOPS! bin for paints at Lowes and Home Depot.
Great job of re-purposing; saved from the dump for many more years of useful life.
nice resto! a dark green might go real well on the plywood. since I'm not allowed to post urls until i've posted 10 times, do a google search for "dark green furniture paint" and look for the Dresser and Nightstands with Valspar Furniture pix. Looks pretty nice and you can probably leave the drawers oak maybe.
Nice up cycle! Always fun and rewarding to bring an old piece back...I have used flat or low sheen acrylic paint, like the sample pots or larger tins if a big job, followed by either 30% matt or 60% semi gloss precat NC lacquer for YEARS on customers bookcase commissions with excellent results. For the handpainted look... yes, brush on the acrylic colour , allow to cure for a couple of days, sand with 400 wet/dry and follow with sprayed lacquer (from a gun, preferably compressor HVLP or LVLP). I learned this from a furniture restorer. It gives a real hand made finish with the surface protection of the lacquer. If you wanted to do wet area cabinet doors, 2 pack lacquer or poly would be the way to go. Don't believe the 'you can't put solvent based finishes over water based finishes' malarkey. Try it out, its easy, forgiving and dirt cheap...Cheers
Jim Pearson
30 yr expat in AUS
1 - 14 of 14 Posts
